Ball Joint - Ford Powerstroke Diesel Forum
Old 12-03-2010, 07:05 AM
<-Day Of Fail now SOLD
Thumbs down Ball Joint
So I finally broke down and put new rubber on the truck and WANTED to get an alignment, but low and behold both lower ball joints are a tad bit loose.
So who has the best price? I was told that powerstrokeshop has a kit, but I cant get the site to come up.
I'm most likely going to do uppers while I've got every thing torn apart.
Old 12-03-2010, 08:16 AM
Old 12-03-2010, 08:41 AM
Ive used napa for them.....theres two different ones, both seemed okay
Old 12-03-2010, 08:52 AM
rockauto maybe?
Old 12-03-2010, 08:55 AM
i used napa in mine.
Old 12-03-2010, 08:57 AM
Powerstroke Junkie
Just make sure you only use Moog joints with zerk fittings, otherwise you will be doing it again, and again.
Old 12-03-2010, 09:18 AM
i think mine were the moog. cant remember right off.
Old 12-03-2010, 09:34 AM
x2 Moog has a lifetime warranty and moog will cover labor also if they go bad.
Old 12-03-2010, 10:45 AM
I am in the same boat. About 15K ago i was told the right lower was loose. Now i have a knocking sound coming from the left side upon bumps and caster situations and suspension travel. I plan on replacing all four. I know we also need Axle knuckle seals and shaft seals but dont know parts numbers or price.
