will 05 F350 blocks fit on my 02 F250? - Ford Powerstroke Diesel Forum
Old 11-25-2010, 01:46 PM
I want to put the f350 rear blocks on my 2002 f250 but can only find a set from 05. I can not imagine they are different but most places list a different set for 05 and newer. Anyone that can tell me for sure if they will work one way or the other i would appricate it. If anyone can compare the part numbers that may work too. thanks for the help.
Old 11-26-2010, 07:19 AM
Feedback Score: 5 reviews
They are all the same same from 99 on up.
Old 11-26-2010, 08:13 AM
As long as they both have the same angle to them they are interchangeable.
They all fit, but if you go from a flat block to a tapered block or vice versa you may get some vibes.
Old 11-26-2010, 08:03 PM
Thanks for clearing that up, right now I have no taper in my 250 blocks. I have the extended cab long bed and have an add a leaf. That said Shoud I use the flat 350 blocks or the tapered ones?
Old 11-27-2010, 06:25 AM
I would stick with the Flat blocks. So out of a Super Cab long bed F-350 or out of a Crew Cab F-350 (both short and long box) will have the 93mm flat blocks from the factory.
Old 11-28-2010, 06:27 PM
will do, thanks for the help
