09 F250 with a vibrating - Ford Powerstroke Diesel Forum
Old 11-18-2010, 03:23 PM
Hey Guys, Just wondering if anyone can help. Just got a 6 inch BDS lift installed on my truck. Now when i start off from stop right on upto 20kms, my truck vibrates, Any sugestions and any cheap quick fixes. Is this serious???
Old 11-18-2010, 03:50 PM
Mine did the same thing after install of 6" lift.
Shop said fords do that. Still believe there must be a fix.
Old 11-18-2010, 04:33 PM
I was talking to bds and they said it was spring warp, the only way to fix it is to remove the blocks and put springs, or traction bars. I wish the dealer would of told me this. I also heard the shime the carrier bearing. Thats why i am looking for sugestions of what would be best to do and how to do it!! Does urs still do it, has it hurt anything?
Old 11-18-2010, 07:30 PM
You need to shim the carrier bearing that is more than likely the whole problem I had to shim mine around 1" with 5.5" blocks all better now! Traction bars are a good idea if you tow any weight or run the truck hard off the line contact Trevor at PMF he can help you out!
Chris
Old 11-18-2010, 07:35 PM
thanks so much for the info, What should i use to space it with. I thought the trucks rear axle was all one piece, and no carrier bearing. New to this sorry. And you think one inch would be good?? Also one last thing sorry, but is there anywhere i can go and find out how to do this??
Old 11-19-2010, 04:05 AM
First check and see if your rear driveshaft is one piece or two! if its two there will be the carrier bearing in the middle attached with two bolts all you would be doing is spacing it down to correct driveline angle. you can buy a kit for this or make one with some flat steel stock and get longer bolts but all trucks are different your may need more or less than mine you have to add and check to get it right. If you can drill some holes you can make the shims! There are some trucks that shims just dont help then here are Pmf carrier brackets that have tons of adjustment to fix the angle of the shaft or cv's in a custom driveshaft just a few options!
Chris
