When I put my truck back to stock, it sat right at 2" higher in the rear. Thats right about where a F250 sits when you buy it new. Its been driving me crazy looking at the rear end up higher. I know from pas experience that I dont want it to sit level because when they sit perfectly level, they look like they are squatting to me. So I decided if I put a 1" spacer in the front it would be abut 1" higher in the rear and would be perfect. So I picked up a 1" TEI spacer. I threw it in today and it sits exactly where I wanted it to. It actually ended up being right at 3/4" of an inch higher in the rear. From the ground to the center highest point of the wheel opening is 41.75" on the front and 42.5" on the rear. Exaclty where I wanted it. Next step is to pick up a set of ICON 2.5" Leveling Kit Coils and cut a coil or so (will take some experimenting) off to get it exactly where it is now except with the ride of the ICON dual rate spring.
Anyway..enough chit chat...here are a few pics after installing the 1" ICON TEI spacer today:
