wheel jerking in 4wd while turning? - Ford Powerstroke Diesel Forum
Old 11-06-2010, 04:13 PM
When I put the truck in 4wd the steering wheel jerks side to side when turning kinda of tight. I don't know if it's my tires (bf goodrich mud terrains) or something in the driveline? Any help would be great.
Old 11-06-2010, 04:18 PM
No, you're never supposed to turn the wheel very far while in 4wd..
It will rip things apart. What you're feeling is it getting in a bind and then releasing.
You can turn it a little and not have a problem. But once you turn it a lot, it'll start jerking.
Old 11-06-2010, 04:20 PM
If you're on a slippery surface you're fine, if you're on a hard surface, it's really hard on the diff.
Old 11-06-2010, 04:43 PM
thanks for the info.
Old 11-06-2010, 05:45 PM
So I can run it on the road in the snow and be ok?
Old 11-06-2010, 06:45 PM
Yeah, just watch turning a sharp corner, but you should be fine, just be aware of what is going on..
Old 11-06-2010, 08:05 PM
Thanks again
Old 11-06-2010, 09:03 PM
You can actually run them up to 100mph in 4x4High, correct me if I'm wrong StarDriver..
That's what they do at the dragstrips at least.. (It's a VERY straight line though.. lol)
When I had a 4x4, I would often drive it for an hour or two a day at 35-40mph. I miss my 4x4
Old 11-06-2010, 09:21 PM
Yea , I have been 70 ish with her in 4x4 . The jerk during steering is completely normal on dry pavement . Like said before , be careful when turning sharp on it .
Old 11-07-2010, 05:57 AM
If you read your Owner's Manual, it recommends to NOT use 4X4 on dry, hard surfaces. It does recommend to put it in 4X4 every so often to keep every thing loose and lubricated.
