Truck is bouncin
i have a 2005 f250 diesel crew cab short bed 6 inch lift with blocks in the back iam running rancho 9000 adjustable resi shocks and at 65+ mph on the freeway the rear of the trucks kinda of bounces how can i fix that
Im not a pro but when that happens is usually the shocks.
i agree^^ but maybe have the tires rebalanced too. ya never know
Mine is doing the exact same thing. Anything over 65mph is about my start of it. On some roads, it doesn't seem to to it as bad. I figured mine was probably carrier bearing, u-joint, or tire balance issue. Never thought of the shocks causing it. Can anyone else shed any light on this.
tires or shocks
Mine was terrible about this then I had the shocks replaced and it was a new truck!
I don’t think a bad balance on tires or bad carrier bearing or u joints would bounce, they vibrate.
I have to check on some new shocks then. I did notice yesterday on the interstate, that when I was on newer pavement, I didn't notice any bounce, but when on 'well used' pavement, it did it.
tires are balanced and i believe the shocks are good they arent that old maybe 25k on them
If they just have 25k they when bad allrady, im assuming that's what happen,not 100% since im not a pro.
