Leveling a 2wd... - Ford Powerstroke Diesel Forum
Old 10-29-2010, 05:53 AM
Leveling a 2wd...
I guess the title is self explanatory. I have a 2003 2wd, and I'd like to level it out a little by lifting the front end. What is the best way to do this, and what is involved in doing it?
Thanks for the help!
Old 11-04-2010, 09:41 AM
I'm wanting to put coil spring spacers on mine. Not trying to hijack but I want to know how bad it throws alignment off?
Old 11-04-2010, 09:45 AM
Haha, no problem. I've been waiting for some kind of a response... maybe someone will see it now and be able to tell us. I know you can put spacers in, but I'm concerned about alignment too, thats why I asked about the best way to do it.
Old 11-04-2010, 10:34 AM
you will have to get it aligned its like $50 to get it done. i know this because my brother did it on his truck and had to get 2 new tires in like a month.
Old 11-04-2010, 11:07 AM
I had a '99 f-250 2wd, Daystar makes a kit for them.
Old 11-04-2010, 12:47 PM
Can the alignment be corrected with stock adjestments or would I need aftermarket bushings?
Maybe it depends on the truck...
Thanks for the help guys!
Old 11-04-2010, 12:54 PM
From a quick search online, it looks like it can be leveled out with a coil spacer
Old 11-04-2010, 12:57 PM
Sweet, I guess I'll just have to take it to an alignment shop and see how much room there is to play with.
Old 11-05-2010, 03:33 AM
if your just going to level it you will be able align the truck with no problems. spend the $50 and your done!
Old 11-05-2010, 03:53 AM
I used the spacer kit and needed new bushings too.
