Leaf Springs to Colis Springs - Ford Powerstroke Diesel Forum
Old 10-14-2010, 06:41 AM
Can you take a 05-07 stock coil suspension and put it on a 99-04. I know the frames are different. I want to upgrade to coils for a better ride and better turning radius. Recommendations?
Old 10-14-2010, 06:56 AM
Feedback Score: 5 reviews
Sure can, get both axles from a '05 up. Lift kits will all bolt right up. 2.5" up kits use 4 link arms for the best ride quality. PM if I can help.
Old 10-14-2010, 09:04 AM
What if I wanted to use the current axles I have?
Old 10-14-2010, 09:15 AM
Their are a couple of kits but will end up more $$ plus will not help the turning radius. You could take your truck to a very experienced 4x4 off road shop and have them build you a 4 link with coilovers..but won't help the turn radius either and cost$$
Old 10-14-2010, 09:34 AM
Well I guess I will go shopping for some used axles. Thanks for the info
Old 10-14-2010, 11:25 AM
aluminum tubing engineer
there are a few afterermarket setups out there...
...B&C Offroad makes one, One Up Offroad makes one, Full traction makes one, and there are other im sure.
http://www.fourwheeler.com/techartic...ion/index.html
Old 10-17-2010, 06:16 PM
I've been wondering about this also, and wanted to know if I get an 05+ axle and a 4 link lift what else is needed? Is the steering the same?
Old 10-18-2010, 01:35 PM
You may need to ream the pitman arm to fit the new Tierod. The track bar bracket may not fit depending on the year axles you get..just weld a new mount on the frame. Sway bar mount will be needed..really all in all very easy. So easy I have kits to do '05 up axles to the OBS trucks..
