question about clocking a transfer case - Ford Powerstroke Diesel Forum
Old 09-12-2010, 08:44 PM
Can I clock my transfer case without a ring. Ive got a four link set up with king coilovers and was wondering if I can clock it down one hole with out the adapter. Thanks in advance
Old 09-12-2010, 09:20 PM
nope... you need a ring... this is the kit you want.. NP 273 Transfer Case Indexing Ring and Crossmember Combo Package - Precision Metal Fab
Trevor is a vendor on here... his stuff is super beefy
-Raul
Old 09-13-2010, 08:27 AM
I have the clocking ring and everything its just that I need more then 25 degrees.
Old 09-13-2010, 11:51 AM
How big of a lift?
I used Trevors ring on the last setting and mine was at a very nice angle even with the full 20" of lift.
Old 09-13-2010, 04:50 PM
id say 20" is about the minimum, it is a custom 4 link with king coilovers I could actually crank it up a little the coils are set at minimum
Old 09-13-2010, 05:52 PM
I think it would be fine with the same ring I had...mine was not at much of an angle at all...actually less angle than when I had 10" with the stock setting.
