Lift install?
Got the readylift 3.5" lift and it looks like its not to hard to install..What should I look out for and what tools do I need?....The track bar bracket looks tough and the nut on that looks huge.Don't even know if I have the right tools,basically I would have to buy what I need but figure at least i'll have the tools.......Is it worth it
Its not a hard job if you have all the proper tools I did my 7" in about 10 hr in south florida heat. 2 good jacks and 4 good jack stands are a huge help if you dont have access to a lift.
Frame side of the track bar is torqued to 400+ ft/lbs. You will need a 3/4 breaker bar and about 4' of extension pipe on that to break it loose and re-install. IIRC it is a 30mm socket. Other than that it is pretty straight forward.
Thx,,still not sure if I want to attempt this in the driveway...
If you don't have the tools..your not a gear head thats loves working on trucks find a Friend who is..
Yup I am a contractor,not a gear head by no means.I know my way around but
You'll need a Tq wrench..jack stands, floor jack, 1/2" ratchet or air tools, sockets etc $$...its not that hard just first time and no tools..where you located?
In nj and i,m not in an area where there are to many shops that do this stuff...I have seen a couple of shops and when I drove the other day to stop by they were both closed up for good.I guess not enough buisness plus the economy really put a hurting on specialty shops....Problem is I would have to buy just about everything i'll need to do this.As a contractor I am prepared for what ever comes at me since you never know what you'll come across and I have all the right tools.But even as easy as you guys say it is,if I get started and there is a problem,who the hell would come to my house,lol
I can't come to your house but I'm available 7 days a week to help my customers who are doing their installs..
Cary |
You can just look around at what you have to take off and re-install and add up all of the sockets, ratchets, wrenches, or any other tools you would need. I was 19 when I installed my 10 inch lift on my first superduty! If a 19 year old with his dads minimal tools can do it you can definitely do it... Just becareful with the track bar bracket, theres a plate in the framerail that the track bar bolts to. Sometimes that plate gets rusted out and the nuts just keep spinning. What I suggest is to loosen that with a ratchet nice and slow just in case it is rusted... Everything else is pretty straight forward...
