Superlift 6inch HELP! - Ford Powerstroke Diesel Forum
Old 08-29-2010, 09:09 AM
I installed the lift this weekend and the big trackarm bracket that bolts up behind the pitman arm has a sloted holes vs a single hole. so the trackbar slides in there causiing the truck to sway side to side when i turn the wheel and the axle is hanging out on the passenger side more than the driverside. is there any way to get this track arm to stay put in that slotted hole vs sliding on me!!!! please help!
Old 08-29-2010, 09:45 AM
I had a bds track bracket that was slotted but it had cam washers that offset it one side or another so it can be used on different size lifts. Is there some sort of metal tabs for a washer to lay against next to the slot you maybe missing the cam washers!
Chris
Old 08-29-2010, 09:51 AM
I just looked on superlifts site you are supposed to have track bar keys basically cam washers here are the details:
55-05-9024................... (2) track bar key
14) TRACK BAR…
 Line up the track bar with the slotted hole of the new track bar bracket.
 Observe the two supplied track bar keys and note that the hole in each key is offset to one
side. Position the keys so that the holes are offset to the driver side and insert them into
the slotted holes of the track bar bracket. Insert the factory track bar bolt through the
bracket, keys, and track bar and secure using the factory hardware. Tighten (406).
IMPORTANT: Yes, the proper torque specification for the track bar eye bolt is 406 lb-ft; this
is not a typographical error. If the appropriate torque wrench is not available, tighten the bolt
as much as possible, then take the vehicle to the Ford Dealer or a heavy equipment repair
shop to perform the final torque operation. Proper torque on this bolt is critical.
no there was nothing! thats y im asking if i may be missing something or is there a way to fix this! Trucktoyz installers and tech yalls input would be great!!! thanks too chris
Old 08-29-2010, 09:52 AM
what website is that and do they have pictures?
Old 08-29-2010, 09:54 AM
superlifts site lookup your year and lift size but no pics of these keys that i saw!
Old 08-29-2010, 09:57 AM
post the link to all the parts that i should have with this lift bc i cant locate it on their website thanks
Old 08-29-2010, 10:03 AM
This is for a 05-07' 6" diesel kit f250 the washers should be almost square with a hole i found them but no pics for like $3.00
01-296 ........................(2) front coil spring, diesel
01-297.........................(2) front coil spring, gas
01-1113........................ pitman arm
55-01-9026 ..................compression stop bracket,........... (1) 3/8” x 1-1/4” bolt
front, driver side (1) 3/8” x 1” bolt
(1) 3/8” USS washer
(2) 3/8” nyloc nut
55-02-9026 ..................compression stop bracket,........... (1) 3/8” x 1-1/4” bolt
front, passenger side (1) 3/8” x 1” bolt
(1) 3/8” USS washer
(2) 3/8” nyloc nut
55-07-9026................... radius arm drop bracket,............. (2) 18mm x 130mm bolt
driver side (4) 18mm washer
(2) 18mm nyloc nut
(2) 1-1/8” OD x 2-3/4” sleeve
(1) 1/2” x 1-1/4” bolt
(1) 1/2” nyloc nut
55-08-9026................... radius arm drop bracket,.............. (2) 18mm x 130mm bolt
passenger side (4) 18mm washer
(2) 18mm nyloc nut
(1) 1/2” nyloc nut
55-06-9026................... steering stabilizer drop................. (1)5/8” x 1-1/2” bolt
bracket (1) 5/8” SAE washer
(1) nyloc nut
(2) 7/16” USS washer
(2) poly bushing half
66-04-9024................... (2) anti-sway bar link extension
55-05-9026................... front track bar bracket
55-07-9024................... (2) brake line extension bracket... (1) 1/4” x 3/4” bolt
(1) 1/4” nyloc nut
(1) 5/16” x 3/4” bolt
(1) 5/16” nyloc nut
FORM #9027.04-012506 PRINTED IN U.S.A. PAGE 3 OF 9
(2) shock absorber, front.............. (2) shock boot, yellow
(2) hardware pack and cable tie
(2) shock absorber, rear............... (2) shock boot, yellow
2 (2) hardware pack and cable tie
00461........................... decal, "Warning To Driver"
Old 08-29-2010, 10:08 AM
thanks a bunch!
Old 08-29-2010, 10:14 AM
No problem hope it helped!
Chris
