Ballistic drag link - Ford Powerstroke Diesel Forum
post #1 of 8 Old 08-27-2010, 11:41 PM Thread Starter
boschert_72's Avatar
Ballistic drag link
So I stumbled across a really sick drag link on here, can't find it again, any ideas?
Late 99 F-250
6" lift
37's
'99.5 F-250 SD PSD CCLB 4X4
Terminator Engineering, aFe, Airdog, Aeromotive, Skyjacker, Pink Stallion, Toyo M/T's, Fuel Octane 20x12's, Garrett, Banks, Diamond Eye, TransGo, Rockford Fosgate, Pioneer, Dp Tuner F6 Live, Aeroforce, BD Diesel, '11 Bed, '10 Bumper,'11 Tailgate, '05 HD heads, HID's, KC's(HID), Home-Made Traction Bars, 4KW Gear Reduction Starter, Ya know.... The Usual.....
Your gunna have to climb over a smokin pile of brass to get my guns!!
boschert_72 is offline
post #2 of 8 Old 08-28-2010, 12:01 AM
KING of BLING!
ExtremeFord4x4's Avatar
Trevor(NotStock) from precision metal fab sells them.
2005 Ford Excursion 4x4 Limited(Current)
2006 F350 Crew Cab 6.0 Lifted 6",22's,SRL, Edge CTS(Totaled)
2003 F250 Crew Cab 6.0 Sonic Blue Sport 38s/20s(SOLD)
2001 F250 Crew Cab 7.3 w/ 08 Clip 37s/22x14s(SOLD)
2005 Excursion Limited 6.0 I.D. Tunes 38s/20s(SOLD)
2008 F350 Crew Cab 6.4 Job II 2.5" Leveling kit(SOLD)
2001 F250 Single Cab Short Bed Looney Tuned 6.0 Conversion Studded/EGR Delete(SOLD)
ExtremeFord4x4 is offline
post #3 of 8 Old 08-28-2010, 03:03 AM
NotStock's Avatar
We use a lot of ballistic joints with our parts. Not the cheapest but its quality American parts!
Precision Metal Fab
Trevor Hall
(520)465-7971
NotStock is offline
post #4 of 8 Old 08-29-2010, 07:03 AM
Feedback Score: -1 reviews
I looked and did not see any steering parts on his site.
nevrnf is offline
post #5 of 8 Old 08-29-2010, 08:47 AM
Pahrump's Avatar
Call him....he makes drag links and track bars...
They look like this..
And when installed like this..
2008 F250 FX4 CC SB Black on Black STOCK and SLOW...Rolled over and TOTALED...
2008 White with Black interior FX4 CCSB
Black C6 Vette
As far as actual HP numbers I have no idea. It don't snap your neck but.....It feels good.
Pahrump is offline
post #6 of 8 Old 09-04-2010, 07:05 PM Thread Starter
Not stock, what do u use to attach the ballistic to the pitman arm? Also why not put a ballistic at both ends?
post #7 of 8 Old 09-05-2010, 03:24 PM
Pahrump's Avatar
A 3/4" Grade 8 bolt runs through the joint and the pitman arm...you have to drill through the pitman arm since its tapered to install it.
Black C6 Vette
Pahrump is offline
post #8 of 8 Old 09-06-2010, 05:49 PM
NotStock's Avatar
3/4" grade 8 fine thread bolt at the pitman arm end. You will need to drill out your pitman arm. There isnt enough clearance at the knuckle side to use a Ballistic joint at that location. Also your factory rod end is built with a long bolt that runs through the knuckle aswell as the bottom rod end. We did some testing with some other rod ends but found the OEM peice to be the must suitable solution. The rod end isnt the weakness, the factory adjuster is the failure point....
Precision Metal Fab
Trevor Hall
(520)465-7971
NotStock is offline
