Rear Suspension Sag - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-18-2010, 04:03 PM Thread Starter
BioStroker's Avatar
Quoted: 4 Post(s)
Rear Suspension Sag
So I have some considerable sag on the back of my truck. I bought the truck with some sort of lift, I'm not sure how much. My front shock measures 19.5" from bolt to bolt (eye to eye). I have 10.5" from the top of the tire to the fender with 315/75/16 tires. The rear measures 9.75" from the tire to the fender. I don't tow often, but I do have a 50 gallon WVO tank in the bed that weighs about 350 pounds when full.
I think I need some add a leafs in the rear-does anybody have any for sale? If somebody thinks I need something different please let me know!
2000 F350 Crew Cab Short Bed,
AIS Intake/Zoodad, 203 thermostat, Billet Housing
Vegistroke WVO conversion, AIH Delete, Wicked Wheel, TurboMaster Wastegate controller
Pyro/Boost/Tranny Guages
4" Magnaflow Straight Pipe
DP-Tuner F6 80hp Econo, 80hp Tow, Decel, 100hp Performance, 120hp Race
BioStroker is offline
post #2 of 4 Old 08-18-2010, 04:28 PM
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
You could try adding some 2" blocks to the rear to level it out. When i put the lift in my Dodge it looked the same way, like it was sagging in the rear. Added some blocks and it looked right after that. Only problem with Add-A-Leafs is that you are never really sure how much rise u will actually get from them. Just my 2 cents!! :-)
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
post #3 of 4 Old 08-18-2010, 05:20 PM Thread Starter
BioStroker's Avatar
Quoted: 4 Post(s)
Thanks. I'm just wondering if my leaf springs are worn out and will reduce the amount of weight I can carry since they regularly sit on the "stopper" bars. (Sorry, not quite sure of the terminology!) That's why I was thinking the add-a-leafs, so I could keep my weight carrying capacity up.
post #4 of 4 Old 08-19-2010, 03:33 PM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
A Deaver rear mini spring pack will get you 2.5" and extra capasity..PM me if you would like additional info.
You could also use air bags.
19.5" is really close to the stock measurement of 19"+-
Cary
CT Performance, Inc. is offline
