Solid axle swap
Aright i think its time for my 1995 f250 to get its solid axles swap. Now question is what year f350 do i need to get the axle from. Also will my brakes rotors work on the solid axle because i just bought them last month.
Find a D60 from a 95-97 your Calipers and rotors will work. Get the TC yoke and the DS along with the sway bar, track bar, brackets and most important the bottom U bolt bracket thats loose and not part of the axle!!!
Hope your planning on a RS-V and B code spring swap..you know you want a great riding truck! We developed this mod 9 years ago and have helped countless OBS owners have the best riding truck. We have everything for this mod. PM me if I can help |
i sent you a email thanks for the help
Ive done two SAS on an OBS truck and neither of them we used the 350 drive shaft
It all depends on the lift..go high enough or drive in Hi range 4x4 and you will need a CV.
I've got prolly 20000 miles on mine with 3 inches of lift and 37s. Been in pretty deep mud too. Never had an issue
3" and stock F250 DS is doable esp with stiff OBS springs that don't move much.
