Track bar install - Ford Powerstroke Diesel Forum
Old 08-06-2010, 11:09 AM
Track bar install
I finally might have the time today to install my 2 inch add a leaf for the front and an adjustable track bar. I already have sprayed the bolts with PB Blaster a few hours ago. Only thing is, im dont have a big enough socket for the bolts.. It looks like a 1 1/4 socket.. Am I right? Before I take a trip to the autoparts and by the wrong size..
Old 08-06-2010, 11:25 AM
use some dial calipers and measure it.
Old 08-06-2010, 11:45 AM
Feedback Score: 5 reviews
Its metric but I use a 1 3/16" You will need a 3/4" slide T handle with a 3/4-1/2 adapter if you don't get a 3/4" socket. You want this so you can use your jack handle or a 4' piece of pipe to get leverage to remove the bolt. Using a 1/2" breaker bar will just break it
Old 08-06-2010, 07:52 PM
A little fire helps too
Old 08-06-2010, 07:58 PM
and just a heads up its a tuff bolt.....I tried gettin mine out and couldnt get it lose, ended up making an appointment to have it installed....gettin it done tuesday...
Old 08-06-2010, 08:50 PM
Here durka durka durka!
Send a message via AIM to EODguyJake Send a message via Yahoo to EODguyJake
Amen to that. When I did my leveling kit and track bar some 5 or 6 years ago, I used 3/4in stuff and a mapp gas torch. Didn't need any breaker bars, and I didn't break anything.
Old 08-07-2010, 06:26 AM
Lbs Lbs is offline
It's a 30mm.
Old 08-07-2010, 06:42 AM
Thanks everybody.. I used a 30mm socket with a 1/2 breaker bar with a 2 foot pipe and broke it loose no problem.. It took me about 30 min to install it after I bought the socket of course...
