8" lift components what all is needed - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-04-2010, 12:39 PM Thread Starter
ncstroker's Avatar
I have an 04 f250 ext cab sb, i have a 4" lift with shackle on it, it already has drop pitman arm, drop track bar bracket, and traction bars, i purchased 8" front springs, 6" rear springs, shocks, adj track bar, extended sway bar links, what else is needed if anything to make it work? i saw something about extended steering coupler, stainless steel brake lines, and carrier bearing drop bracket any help would be appreciated
ncstroker is offline
post #2 of 9 Old 08-04-2010, 06:45 PM Thread Starter
ncstroker's Avatar
bump anyone???
post #3 of 9 Old 08-05-2010, 11:33 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Left you a reply on another forum..are you doing a 8" lift or wanting a 12"..
CT Performance, Inc. is offline
post #4 of 9 Old 08-05-2010, 11:42 AM Thread Starter
ncstroker's Avatar
8" lift, thanks
post #5 of 9 Old 08-05-2010, 11:59 AM
Quoted: 3 Post(s)
You need the carrier bearing drop kit or a index ring, front DS will also need to be made longer or get the index ring. New U bolts should be used. Bump stop spacers.
We have everything needed..if we can help please PM.
Cary
post #6 of 9 Old 08-07-2010, 07:52 AM
Flapdisk's Avatar
Hey man My old truck I bought 10 inch springs for the front and 8 inch for the rear... You definitely need a dual steering stabilizer, make sure that drop pitman arm works for an 8 inch lift because they make them different sizes, I like using the track bar drop bracket so if you want to add drop hanger kit for an 11.5 inch lift later you can just adjust the track bar a little then having it at a bad angle, longer brake lines, new u bolts, good shocks, carrier bearing spacer i think it goes every 4 inches you lift the truck you need to drop the carrier 1 inch if im not mistaken, I think thats pretty much everything if i forgot something just let me know...
Flapdisk is offline
post #7 of 9 Old 08-07-2010, 08:34 AM
Flapdisk's Avatar
[IMG]C:\Documents and Settings\JJ\My Documents\My Pictures\2006_02_25\IMG_0080.JPG[/IMG]
The red bracket is the trac bar drop.. This is my old truck with the 10 inch lift...
Flapdisk is offline
post #8 of 9 Old 08-07-2010, 09:55 AM
NotStock's Avatar
Ehhhhh, Im gonna have to disagree on that one.... No indexing ring nor drive shaft mods are needed for a truck with only a 8" lift. If we were talking 10", it would be recommended but again prob not necessary unless they run in 4x4 alot. At 12" its reguired. Not trying to start anything, I just tend to disagree on this one........
Precision Metal Fab
Trevor Hall
(520)465-7971
NotStock is offline
post #9 of 9 Old 08-08-2010, 10:11 AM
DCSpecial's Avatar
At an 8" you'll most likely want to get the front driveshaft extended, especially if you have springs that push the center pin forward (like the Icons).
An indexing ring would only lower the front output....do nothing for the rear, short of pushing the t-case rearward a little.
With an extended cab short bed, I'm fairly certain you have a one piece driveline in the rear.......so no carrier bearing is there, no need to drop it. You may need to extend it.
Depending on the lift you have now, you also may need a different drop trac bar, pitman arm, etc..
DCSpecial is offline
