Hydraulic steering assists
Has anyone used them and if so where did you purchase them from and what was the price for it.
Im running a PSC kit on my truck. The kit included a new steering box, ram, weld on mounts, and lines. They also recommend an upgraded pump but I didnt get that. Turns my 44's effortlessly at idle and I havent had any issues in the 30k miles I have had it. dont remember what I paid, I think it was somewhere around $600
i was tossing this idea around also.... Steering was tighter or felt about the same after?
Ehh hard to say. My steering box was shoot. Too many miles of big tires and beating on it. I needed to buy a new box anyway so I figured it would be a great time to upgrade to the hydraulic assist. Turning is easy at idle while stopped, which before wasnt possible.
i made my own set up. tapped the gear box and bought a ram and hydro hose from tsc. i had 40's at the time and like said above you could turn em with out moving. i bought a ram mount from diy4x,com the one that bolts the the front diff cover.
Hydraulic assist Ram mount |
I am thinking about doing this on my truck. It is a real beotch to turn my 37's when sitting still.
I could not find a write up on how to do this anywhere on the forum.
Yeah I would appreciate if someone could take pictures and if they have installation instructions attach those as well. And hell if there are non I might have to make a trip back home to phoenix and stop by your shop
it is pretty easy to tap gear box and set everything up. here are a few links.
I did mine in maybe 1.5hr or so. you will need two taps and have to shorten one. hope this helps. Ford Steering Box Adaptation For Hydro Assist Steering Pirate4x4.Com - The largest off roading website in the world. Hyraulic Steering 101 - Source Guide - Four Wheeler Magazine Box Mount - 4Wheel & Off-Road Magazine |
You could do something like the OUO truss with a ram and stabilizer on it.
Here's the truss with dual stabs on a 08-10 SD: And here is the 99-04 style with the ram on one side and stabilizer on the other:
Couldn't you ditch the stabilizers once you add the ram assist? Or do you still need to have them?
