HELP! leveling kit problem - Ford Powerstroke Diesel Forum
Old 07-10-2010, 01:26 PM
i'm an idiot. got it done.
mods delete this thread if you get a chance.
Old 07-10-2010, 03:16 PM
as long as the shock is out and the sway bar disconnected and the little bracket that holds the break line to the coil spring mount on the bottom is disconnected. just keep lifting the truck from the frame till the coil spring falls out, you got to go pretty high and then you will need to go 2" higher to get the spring back in once the spacer is in. Thats how i did it.
And you will need a adj track bar to re center the axle after it's all done or it will be pulled to the drivers side 1/2-3/4 inch.
