rough country 3" pics - Ford Powerstroke Diesel Forum
Old 07-02-2010, 11:05 AM
Anybody have any pics of their 3" rough country lift with 35's?..Is the spring kit a full 3" or are you better off with the spacer kit,,thx
Old 07-14-2010, 12:10 PM
nobody with this combo?
Old 07-16-2010, 07:34 PM
If I go with the spring kit can I use a 1/2" spacer?,,Like the icon spacer...
Old 07-17-2010, 12:27 PM
i would call ryan at R&R Off Road or talk to one of the guys at Truck Toyz
Old 07-18-2010, 03:44 AM
I hope that some body will come through because I'm planning on using this kit my self! Probably am going to use the the spacers so I can keep my plow prep springs. I also think i'm going to need a 5 inch rear block because I am already pretty level.
Old 07-18-2010, 07:53 AM
Thats what I want to see also.I like a little bit of rake in the front.I was thinking of putting a 1" block in the rear with the 3" spacer in the front and It should look good..I have a 2" spacer now and like the look.But I have a set of 35's I would like to mount but I think it would look better with that xtra inch.I also want to keep my springs.I have the 6000lb springs.Is that the plow spring?
Old 07-18-2010, 10:26 AM
Plow prep,HD service,Camper pkg could be any one of those or a combo.I have Plow prep and camper pkg on my truck
Old 07-18-2010, 10:36 AM
Look at the pic in my signature. Its a 3" (2.5") Rough Country Add-a-Leaf at each corner (leveling kit with same height add-a-leaf in rear) and running on LT295.70R18's (35x11.5x18) Nitto Terra's. I can send you more pictures of the truck too if needed. Mine has the plow prep and camper package.
Old 07-18-2010, 01:18 PM
I greatly appreciate the pictures, But our trucks are the 05 and up with the coil spring front end.
Old 07-18-2010, 04:25 PM
Yup,I can't believe nobody is running this combo.I have seen alot of peeps using this kit but no pics with 35's.....
