Serious hopping problems - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-27-2010, 06:09 AM Thread Starter
Feedback Score: -1 reviews
My brother and I hooked up back to back last night on the pad, and I was sure I was going to take him being that I have 35x12.50 all terrains and he has super-small stock tires on his mega cab. Anyway, he killed me twice; from each end of the pad
The major issue I ran into was my truck was hopping - bad. I mean so bad I couldn't even apply any pedal to it - all I could do was let off the brake just about. It was a fast hop - not the whole truck at once hoping slow like my Bronco used to do, but as in all the tires(especially the front) quickly bouncing up and down. Pretty much the same thing all around as what pickups do in the rear when spinning in the sand while unloaded...
Both of us were in 4lo, his truck didn't hop at all - just straight drug me around like a damned lawn trailer
Anybody ever run into this issue too? I know my shocks are all not exactly new, but I've seen other SD's do this so mabye I just have to live with it. My truck has a leveling kit and the BFG's but that's it.
-Matt
mmccraney is offline
post #2 of 6 Old 06-27-2010, 06:49 AM
dereku's Avatar
Feedback Score: 7 reviews
Send a message via AIM to dereku
Are your gears in the front and back the same haha?? my 96 did that when I had 3.55 and 4.10s
2002 f250 BFT Edition
dereku is offline
post #3 of 6 Old 06-27-2010, 06:52 AM
DirtyDiesel's Avatar
Quoted: 4 Post(s)
. dam fun night.
wat ur talking about is axle chatter, my truck doe sit BAD in loose dirt when i jus barely spin. if i hit the throttle i can power thru it. i talked to a guy about it on the cumminsforum, he says it does it because there is too much air in the tires. shoulda aired down, then maybe ida had to actually giv it some throttle to pull u bak.
Brett
'08 Ford F-350 Powerstroke Lariet 4x4
SPARTAN Tuner, Flo-Pro 5" Exhaust 6" Tip, Deleted, S&B Intake, B&W Hitch, 2.5" Leveling kit, Custom Rear Traction Bars, 20x12 FUEL NUTZ, 33x12.5 Toyo MT's, PIONEER Screen, 3500W of ORION amps, Sundown SD3 10" subs, Blacked out Headlights, Retro LED bulbs, Recon Mirror Lights
DirtyDiesel is offline
post #4 of 6 Old 06-27-2010, 07:38 AM Thread Starter
No actually I have no idea - the tag in the door says I have 3.55's, it sure runs like I have 3.55's, but then again I bought it used so they could be anything. I need 4.10's anyway...
Originally Posted by DirtyDiesel View Post
. dam fun night.
I know what its called - I need to know how to get rid of it. That was BS - hell I had a hard time gettin to my end of the pad with that CC F150 in tow And what's weird is mine does not do it while in the dirt like you're talking about - and like it was doing when you were trying to get off that hill last night
I was thinking about the air pressure too last night and I wanted to air down, but I had no way of airing back up again. I wasn't about to roll home pulling the quads with 10psi of air in my tires. I'm still thinking I need new shocks - if they were new and valved right I think they'd be better able to control the spring movement...
Oh, and you may be bale to power thru in the dirt, but there was no way I was going to try that on the pad and tear my shiz up. It was fun though - we had quite a crown out there by the time we were done
post #5 of 6 Old 06-27-2010, 08:03 AM
Quoted: 4 Post(s)
i wasnt gonna go public with that.
not here was no way u could power thru wat ur truck was doin. the more throttle u gave it the harder it chattered. i think if ida aired down to 40psi (instead of 80) i coulda takin the v10 on 36s.
Brett
post #6 of 6 Old 06-27-2010, 08:23 AM Thread Starter
I don't mind it being out there; I'm not going to cry over it. Its not like he out-powered me; back to back is a traction game, and its hard to get any when your tires are jumping off the ground 100 times a sec. He had some pretty nice tires too though...
What also was weird was that he (Mr. F150) was coil sprung too and he wasn't hopping around like a jackrabbit either, and neither were you I dunno - maybe tire pressure had something to do with it as well. I'm still thinking shocks though.
-Matt
