96 F250 dana swap...track bar? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-16-2010, 08:21 PM Thread Starter
So I have looked over other threads and nobody has touched on this that I could tell. I am doing a dana 60 swap this weekend and am wondering if I really need to worry about installing the track bar. I figured they have run leaf front ends for years without the bar so is it really needed?
MCManufacturing is offline
post #2 of 10 Old 06-17-2010, 04:27 PM
Quoted: 4 Post(s)
Feedback Score: 5 reviews
Its has been covered many many times..must use one! Sure hope your doing a RS kit and SD springs..ya do want a great riding truck..
CT Performance, Inc. is offline
post #3 of 10 Old 06-17-2010, 04:32 PM
the baconator
terryknight's Avatar
Quoted: 153 Post(s)
no you don't NEED to, but i wouldn't recommend doing it without the track bar.
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #4 of 10 Old 06-17-2010, 04:37 PM
swamp_ratt's Avatar
what is the significance and importance of the track bar? like he says, theres been leaf front ends for long time with out em
1995 F350 CCLB DT360/Allison
1997 F350 RCLB 460/E40D
2001 Jetta TDI 5spd (51mpg work beater)
1995 F350 CCLB 2.5 tons/57s Front, 53s Rear
swamp_ratt is offline
post #5 of 10 Old 06-17-2010, 06:03 PM
the baconator
Quoted: 153 Post(s)
it keeps the truck heading straight and rocking side to side aka death wobble
post #6 of 10 Old 06-17-2010, 07:14 PM Thread Starter
Good point. I pulled wrenches for dodge for years. Granted they run a coil front end but when that track bar starts to wear they death shake like crazy.
post #7 of 10 Old 06-17-2010, 08:10 PM Thread Starter
OK, Next quiestion. Are you guys just fabing up your own track bar mount on the frame side or is there somthing else I have to go back to the junk yard for? Note: truck has 4 in lift under it.
post #8 of 10 Old 06-18-2010, 05:12 AM
the baconator
Quoted: 153 Post(s)
you can fab one up or buy and aftermarket one. with a 4 in lift you'll need either a drop bracket or an adjustable trackbar.
post #9 of 10 Old 06-18-2010, 05:16 AM
DirtyDiesel's Avatar
Quoted: 4 Post(s)
i ran the black truck in my avatar for years without a TB. i only got the death wobble when i went to the 37" irok bias ply tires. there was quite a bit of steering play/delayed reaction tho i do hav to say.
the guythat bought the truck from me put a track bar on and said it was like driving a completly different truck. i would recommend putting one on but u dont really hav to.
Brett
'08 Ford F-350 Powerstroke Lariet 4x4
SPARTAN Tuner, Flo-Pro 5" Exhaust 6" Tip, Deleted, S&B Intake, B&W Hitch, 2.5" Leveling kit, Custom Rear Traction Bars, 20x12 FUEL NUTZ, 33x12.5 Toyo MT's, PIONEER Screen, 3500W of ORION amps, Sundown SD3 10" subs, Blacked out Headlights, Retro LED bulbs, Recon Mirror Lights
DirtyDiesel is offline
post #10 of 10 Old 07-01-2010, 12:50 PM
you definitely want a trac bar,if not it will drive like a 80s model chevy.I might have a factory trac bar and bracket in the yard,if i do you can have it.as for a drop bracket........use a piece of 1/2 inch plate steel on the crossmember and bolt the factory bracket to it.
fordtough4x41985 is offline
