adding a block vs. replacing with full block - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-15-2010, 10:59 AM Thread Starter
1ynggun's Avatar
Quoted: 6 Post(s)
I am looking to add a few inches to the rear. My options are to add a 1.5 inch block on top of factory or replace the whole thing with a 3.5 inch block. What do you guys run or recommend?
2014 F-250 CC Lariat
Blue Jeans Metallic
Black tonneau cover
1.5 Readylift level Kit w/ 350 blocks
35x12.50 Geolander MTs
20'' Platinum Wheels
1ynggun is offline
post #2 of 9 Old 06-15-2010, 11:03 AM
NotStock's Avatar
I wouldnt stack blocks unless its a temp deal. Just buy one single setup....
Precision Metal Fab
Trevor Hall
(520)465-7971
NotStock is offline
post #3 of 9 Old 06-15-2010, 11:08 AM
96cobra10101's Avatar
+1.
RCX 6" 4 link lift w/ dual stab, 20" BMF wheels, Nitto Trail Grapplers 37x12.5x20
*Wish list* Spartan kit, Train Horn, Recon Cab Lights
96cobra10101 is offline
post #4 of 9 Old 06-15-2010, 11:10 AM
Don't you worry about it
strokinpower's Avatar
Quoted: 277 Post(s)
yea I hate to say it but that was kind of a no brainer... single block
strokinpower is offline
post #5 of 9 Old 06-15-2010, 11:19 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 30 Post(s)
Get a set of traction blocks from Notstock.
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #6 of 9 Old 06-15-2010, 11:22 AM
smokenstroke's Avatar
Quoted: 8 Post(s)
Get a set of stock 350 blocks, they are 3 5/8'', that'd be close and they have the bump stops and angled.
2002 F250
Tunes
Intake
Exhaust
Turbo
Injectors
Traction Bars
smokenstroke is offline
post #7 of 9 Old 06-15-2010, 11:30 AM Thread Starter
1ynggun's Avatar
Quoted: 6 Post(s)
will i need new ubolts to fit the 350 blocks? would 2.5 inches up front put it dead level?
Blue Jeans Metallic
Black tonneau cover
1ynggun is offline
post #8 of 9 Old 06-15-2010, 11:37 AM
NotStock's Avatar
Check to see how much of your ubolts stick out above the top spring plate. That is how much larger of a block you could add without needing new ubolts. Typically its recommended to run a 1" taller block in the rear than the front, so yes a 3.5" block in the rear with a 2.5" leveling kit would sit almost level, maybe rear high by 1/2".
If your curious about the stance of the truck, park on level ground and measure from the top of your tire to the top of the fender gap both front and rear....
Precision Metal Fab
Trevor Hall
(520)465-7971
NotStock is offline
post #9 of 9 Old 06-15-2010, 11:45 AM Thread Starter
1ynggun's Avatar
Quoted: 6 Post(s)
i would need a flat 350 block as i have a two piece drive shaft, i beleive
Blue Jeans Metallic
Black tonneau cover
1ynggun is offline
