steering locks
just put in a 6.5 inch lift and was taking it for a drive was fine for a day and then the steering started to lock up. you can still move the wheel but it Catches when you turn and you have to jerk it out and then caches the other way. is this a bad steering/pump(drowing a blank on its name)were the pitman arm attached or does it just need an aliment. i was told i could get some camber adjustment with the alignment any help would be great wont to get the truck going and stop using the car
Mine just started to do the same thing but I recently took my lift off and went back to stock. Have you found anything on this yet?
i am going to get it pick it up now from allinment will see if that was it
