12" lift, rear kelderman helper bags? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-10-2010, 02:53 PM Thread Starter
I have a 12" fabtech lift, the back end is pretty stiff. I am looking to make it ride better and dont want to really put different springs with taller blocks. I was thinking about the rear Kelderman helper bag lift that bolts underneath the truck where the hitch is. It connects to the rear leaf spring hanger. I just dont know how its gonna work and if it will help or not. Anybody try this kit out? I did some searching and couldnt find much on it.It looks like a good kit and sells for 1,300.
ramagost0408 is offline
post #2 of 6 Old 06-11-2010, 08:21 AM
Pahrump's Avatar
I dont think its gonna help..only if you REMOVE the springs..and use bags will you get a better ride.
2008 F250 FX4 CC SB Black on Black STOCK and SLOW...Rolled over and TOTALED...
2008 White with Black interior FX4 CCSB
Black C6 Vette
As far as actual HP numbers I have no idea. It don't snap your neck but.....It feels good.
Pahrump is offline
post #3 of 6 Old 06-11-2010, 08:28 AM
NotStock's Avatar
What year truck? If its a 99-07, you could convert to '08 springs if you wanted to stick with a traditional non air setup. A local guy has a helper bag type setup from Kelderman and hates it. On his he had to modify the springs to the point where he cant take the system off unless he replaces the springs, I dunno if thats the same system you were looking at or not.
Precision Metal Fab
Trevor Hall
(520)465-7971
NotStock is offline
post #4 of 6 Old 06-11-2010, 08:35 AM
What is the difference between the new springs and where does one get them?
Thanks,
Mobspade is offline
post #5 of 6 Old 06-11-2010, 08:53 AM
NotStock's Avatar
The '08-10 trucks use a longer spring. This allows for a higher payload capacity and a softer ride. You have to get conversion hangers to run the '08 springs on a 99-07 truck.
Precision Metal Fab
Trevor Hall
(520)465-7971
NotStock is offline
post #6 of 6 Old 06-11-2010, 09:01 AM
Any idea where to find this stuff?
Thanks
Mobspade is offline
