04 superduty, 4" lift: Popping in front end - Ford Powerstroke Diesel Forum
Old 06-01-2010, 09:07 AM
Send a message via AIM to Jason.
Ok, so I lifted the wifes truck 4" and now its popping in the front when you either turn all the way or hit a bump. At first I was thinking the track bar wasn't tight enough, but it is at 395 ft-lbs which is factory ford spec. Now I'm not really sure what else it could be that's doing it? maybe the shackles aren't tight enough, or the ubolts aren't tight enough? Any other thoughts as to what it could be?? Shes on me to fix it, so wednesday I'll spend my day off fixing whatever is wrong with it.
Old 06-01-2010, 09:09 AM
Also to mention, some of you will say its the sway bar bushings, but Well, there's the thing. The sway bar isn't on the truck right now because I'm waiting on my extended end links to come in, BUT when I had the truck it had an 8" lift for 2yrs and I never ran a sway bar, and it didn't make one single pop sound and road amazing for a leaf sprung truck. Now I lower it down to a 4" lift, and it's popping? Just puzzled right now.
Old 06-01-2010, 09:35 AM
KING of BLING!
Sounds like the leaf spring bushings. I would have thought it was the trac bar too at first.
Old 06-01-2010, 10:01 AM
Sounds like a bushing somewhere i lifted a buddy of mines truck and the lift from skyjacker was missing a few bushings making it do the same thingyour describing
Old 06-01-2010, 10:02 AM
mine does the same on my 4.5 dr hanger kit... everything has been tighten to ford spec.. but now that i got about 1000miles on the kit mabye i should retighten everything? i dunno.
Old 06-01-2010, 10:06 AM
Probably leaf spring bushings mine does the same thing when its cold outside
Old 06-07-2010, 07:20 PM
bump for more information on this... im gonna have a friend watch/listen to the noise when i slowly go up an incline, to see if we can narrow it down.
Old 06-07-2010, 07:34 PM
mine was doing it, changed to X code springs, and it stopped. Now my leaf spring bushing just squeak now.
