have a 4" lift but want few more inches-shackles or mini pack - Ford Powerstroke Diesel Forum
Old 06-01-2010, 03:41 AM
Ok i have a 4" procomp on my 99 250 reg cab. She is riding on some 36x13/16 tsl's. No rubbing but a little on my lower valance. When these tires are done i want to go with some 37's. The rear im just gonna block
So my question is for the front- 2" Shackle Kit or 1.5"-2" mini leaf?
Also if i do either of those what are the odds i will have to do something with my brake lines?
Also with the shackle kits- do those just replace the rear bracket on each side?
Old 06-01-2010, 05:57 AM
when you do shackles, do hangers as well. check out sky manufacturing for there kits.
Old 06-01-2010, 06:10 AM
do a shackle and hanger kit... Id go though PMF. Send Notstock on here a PM and he will get you fixed up.
Old 06-01-2010, 07:28 AM
SAK SAK is offline
You can not run mini-leafs on aftermarket lift spring.
It is also not as easy as throwing lift shackles at it. You need to make sure you have the supporting components to accommodate the additional lift. You are going to need an adjustable track bar, longer shocks and longer sway bar links to do this.
We carry all the parts that you would need, PM me if you would like more pricing on it all.
