2010 track bar and bump stops
hey , just woundering if I need to get an adj trackbar or drop bracket with my bilstine 2.5 level kit(same as icon)also i thought i read that i need to do something with the bump stops in the front...any truth to this?
thanks again.... |
I put on the Bilstein kit with an Icon track bar. I did not do anything with the bump stops. It might have worked just fine with out the adj. track bar, but I am picky. It does ride well with all that stuff on there. I am not sure if it is because the nice urethane bushing in the top of the new track bar or not.
You must use a adj track bar or correctly made drop bracket as every 2" of lift WILL shift the axle 1/2-3/4" Its Geometry.
Bump stops are fine if your shocks don't bottom out. |
