Sway bar end links
Just had my guy throw some 4" front springs on my truck while doing a hub assembly and he said i need extended sway bar links. Anyone have any or know where to grab a set??? thanks guys! he says since i dont pull much i can run without sway bar until i find some but there will be some sway in the truck thanks!!
Its a 01 7.3 4x4 F250 Last edited by smokeyd; 05-19-2010 at 06:00 PM. Reason: more info |
how about steering correction, trac bar, shocks, or the rear?
Where are you at. I have some on my truck and i need stock ones.
im in Tennessee,
It was a lift kit taken off a truck. So i have pitman arm, double shocks up front. just need sway bar end links, buy a new front dual shock stabalizer and a solid back block since the guy had them stacked |
10-4...I used some stock rear links off a 2000 for front links for a 4 inch lift. that was the quickest option, did it on fri and the ford dealer had the links in stock so i could complete the lift to go to the beach for the weekend.
hmmmm good thinking, how much those run you from the dealer???
well on an 01 for some reason i think the left and right front sway bar links are differant
Cut and sleave them..
Cut and weld a longer tube on that goes over the orig link? how much you recon i would need to add? 4"
How long are yours. If mine will work I can ship you mine and then you ship yours back to me?
