violent vibrations around 40-45 mph - Ford Powerstroke Diesel Forum
Old 05-16-2010, 12:03 AM
i've had this problem for a while. when i first got the truck used i didn't notice it too much cuz i didn't really hover around that speed. but now i have to drive at 40 mph a lot and everytime i do the truck starts to vibrate pretty violently. it starts at 40 mph and stops at 45...and if i blow past that speed i dont really feel it. it's really weird. i thought it might be my balance so i had the tires balanced and rotated but nothing. anyone have any idea what this might be...? i'm just worried it might be the start of something bigger and worse to come. any help would be awesom. thanks all.
Old 05-16-2010, 12:11 AM
is this truck a crew cab? ex cab?
check your carrage bearing under the bed where the cab ends. check for play in the shaft.
Old 05-16-2010, 01:15 PM
yea it's an extended cab...sorry.
Old 05-25-2010, 01:05 PM
I had the same exact problem, only between those speeds and it wasn't balance or alignment, it was a worn rag link and TRE. Once it was replaced everything was back to normal.
I was convinced it was ball joints and bearings going or track bar which was almost new going again.
Old 06-06-2010, 05:09 PM
i have the same problem , i don't feel the vibration in the steering wheel , but the whole truck is vibrating,do you think drag link,tie rods would cause this
Old 06-09-2010, 06:50 AM
If the whole truck is shaking I'd think it was a tire and wheel balance issue.
Old 06-09-2010, 07:13 AM
tires & wheels been checked & balanced 4 times ,even had tires replaced still have vibration 45-50 mph
Old 06-09-2010, 05:36 PM
U joints on these trucks don't come with grease fittings...at least 02' didn't...Chances are your needle bearings in your U joints are warn out....Drop your drive shaft and take your U joint apart...An old truck of mine had this issue...dropped the shaft and took the U joint apart and dust came out where the needle bearings were supposed to be...On the front of my pop's 31' Model A it must have 30 grease fittings...If we pay as much as we do for these Super duty s I think there should be grease fittings on the U joints...
sorry for the lengthy post
Hope this helps
Old 06-10-2010, 09:22 AM
i checked all u=joints,carrier bearing ,wheel bearings didn't find anything loose
Old 06-10-2010, 09:33 AM
Mine was doing the same thing and it was U-joints.
