Stretching a rize 12 on coils
How far can i crank my coilovers, I have heard my lift kit can be taken to 16" but im not sure how true that is. If that was the case, would i be able to run 44's without cut outs? If anyone has any input it would certainly be apreceated!
I wouldn't recommend stretching it to 16". Steeper angles for the steering, 4-link and drivelines.
I have seen them taken to 14-16" many times...
ANd yes you can clear 44's...mine clears 44"s easy with only about 14" on it right now. |
Thanks Pahrump, How did those big michelins ride?
I have seen, worked on and driven them stretched to 14-16". However, I still don't recommend stretching them that far.
is it ok to stretch the rize 8inch to a 12 inch on a 2009 f250?If the drag link/track bar is changed?will i still be able to get proper caster at 12 inches of lift
The 4-link itself is the same between the 8" and 12". However for the 05-07s the 12" kit includes a different box kit (trac bar mount, centerlink/idler arm steering, etc..). They don't offer this for the 08+. You will definitely need to go to a custom steering setup at 12" since the stock steering can't safely be run at that height. |
People like to make it sound like much more than it is....on the steering stuff.
Flip the track bar, get an adjustable one and have a custom one piece drag link built up with like tie rod ends/heims on each end...do away with the split stock adjuster. |
