01 f-350 front end noise
ok so i have at 2001 psd with a leveling kit and 35 and a few days a go it started to make what sounds to be the tires rubbing on something when i turn left only slightly at first i just thought it was the mud flaps so i took them off but it still makes the noise and cannot find anything rubbing and i also checked the ball joints cus it makes the noise when hitting bumps as well. just wondering if any one else has ran into this problem.
Could also be a wheel bearing.
gonna bump this up for you again bud. I am having the same issues with my 03. I have replaced tires, hubs with warn lockouts, brakes, and both wheel bearings. I still have that same dang howl especially when i turn to the left ever so slightly. I am wondering if its balljoints causing the wheel bearing to have a weird angle and howl then. No one can give me any other explanations.
