Widest tires w/ leveling kit - Ford Powerstroke Diesel Forum
Old 05-01-2010, 07:03 PM
I like the look of wide tires and am Kind of planning ahead here. I'm wondering what the widest tire I can fit with minimal rubbing. I know backspacing is important and I'd like any suggestions. Pics would be good too. I will be leveling my truck with a 2.5 spring pack in the next few weeks.
Old 05-01-2010, 07:09 PM
I'm running 295/70R18 on 18x9 DC2 with no rubbing. My truck is a '03 so I have front leaf springs. My tires are 1" off the springs at full lock.
325's should fit though and would look good. But will have minimal rubbing.
you might fit a 33x15.5 with a dc-1 "maybe" dont take my word for it but i think it would fit but if not the the widest youll get is a 13.5 which sticks out a decent amount my 315/75s stick out close to 2 inches on both sides with my 16.8 wheels on my 99
Old 05-01-2010, 07:22 PM
i got 33x15.5r16 on 16x10 raceline rims and i have a 6 inch lift and the rub my bumper turn hard while going fast in to a parking spot. but there are some people on here running the same tire on 18x12 dc1s with leveling kit and they say they dont rub
Old 05-01-2010, 07:37 PM
I wish the chrome DC-1s came in 18x12. What size tire would I have to run? 33?
Old 05-01-2010, 07:57 PM
Pointless Poster
im runnin 315/75/16s on my truck and they rub on the bumper and inner fender
Old 05-01-2010, 08:12 PM
Im running 305 mud tires on 16 inch stock rims with no rubbing. I also went off road to go hunting and no rubbing either. no lift on the truck although I do have a set of 2 inch shackles
Old 05-01-2010, 10:00 PM
A 325 will fit with no rub (leafs) as long as you get a wheel that has right at 4.5" BS.
Old 05-02-2010, 07:10 AM
they do make a 18x12 in dc-1 i thought? maybe they discontinued them. i remember seeing them before somewhere but if you get the 18s id stick with the 13.5s itll look good on it id get the black dc-2s
Old 05-02-2010, 07:19 AM
on my 03 i had 18x9.5 pro comps with a 33x12.50 and the were close to rubbing.. i had to pull the plastic fender piece back a little.. but i only had an add-a-leaf so if you can actually get 2.5'' out of your leveling kit then you can go a little bigger...
