How to tell what gears I have? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-27-2010, 11:53 AM Thread Starter
gonesurfing's Avatar
Location: surfing, spearfishing, using my powerstroke to tow boats to the river!
Hey guys, I bought my truck used and it already had a 6" lift on 37s. I'm curious what gears I have on my truck and want to know if the prior owner switched them from stock. I haven't gotten a programmer yet so my speedo hasn't been calibrated for the larger tires. When my speedo says 55mph I'm down around 1550-1600rpms. And when my speedo says 55mpg I'm actually going about 60mpg calculated by gps. Anyone have an idea of what I've got? Also, if I pull the rear cover off how do I go about calculating my gearing? Thanks!!!
'05 f350 FX4 CCLB
6" pro comp lift w/Fox shocks
37"x13.50"x20" pro comp Xterrains
4" MBRP turbo-back w/cat delete
Airaid cold air intake
Bulletproof diesel egr cooler and oil cooler
gonesurfing is offline
post #2 of 7 Old 04-27-2010, 01:37 PM
MDarrough's Avatar
I would wager that you have 3.73 gears, but there should be a small metal tag on the rear diff under one of the diff cover bolts.
Mark
2011 F-350 4X4 Dually Lariat pulling a 2010 Sierra 355QBQ 5er --
MDarrough is offline
post #3 of 7 Old 04-27-2010, 01:40 PM Thread Starter
I swapped my cover out and have an '08 cover now. I still had my stock 3.73 tag on there when I switched out the covers but I know thats not a sure bet they are still stock.
'05 f350 FX4 CCLB
post #4 of 7 Old 04-27-2010, 04:55 PM
Michael707's Avatar
isnt it something like every turn of the axle how ever many turns the diff did thats the gear ratio or something? idk it was just a guess
Michael707 is offline
post #5 of 7 Old 04-27-2010, 06:57 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Yes, jack it up, put it in neutral, have someone turn a wheel 1 revolution and count the revolutions the driveshaft makes. If it goes around about 3 3/4 times they are 3.73's. If it goes around a little more than 4 times it's a 4.10, 4 1/2 times 4.56, etc.
RIP Mitch
the Org crew
PGreenSVT is offline
post #6 of 7 Old 04-28-2010, 09:57 AM
Michael707's Avatar
cool man i was right for once
96 7.3 PSD
240,000 miles
diesel innovations chip
11 inch lift that eats my 38s
basically a rolling cloud
post #7 of 7 Old 04-28-2010, 09:59 AM Thread Starter
sweet! Thanks
'05 f350 FX4 CCLB
