Alignment Question
07 F350 2.5 leveling kit with track bar bracket, bringing it in to get aligned and I see some people that have shims available. Do i need these?and what should I have the tech set my caster/camber to?
You'll want caster cams to get back the caster that you lost by doing the leveling kit.
ask the alignment guy to set it back to stock specs, that is all.
I got the Icon kit and it comes with the cams, however, the alignment tech eneded up swapping one of the cams for a different one. He said it was correct for one side, but just a tad off for the other.
So yes, you need them for it to be done right. Mark |
It can't be done without the shims..also stock castor is inadequate IMO.. |
