Cast Iron Spring Spacer Failure. (pics)
The other day I noticed a crack in my overload spring spacer. I removed it only to find that it is made out of cast iron & is not even solid. It was broken completely in half. Knowing that if this thing fails & falls off, my rear axle would be loose, I decided to make it better.
I went to the local metal yard & bought some solid aluminum stock. Solid steel would work fine too. Here is a picture of my overload springs, the broken spacer, unbroken spacer, & my new aluminum spacers. ![]() Installed B4 u-bolts
Very interesting. Thanks for posting pics and info on this.
Your welcome. It was funny, the other day I was at the auto salvage yard. There were about 5 ford pickups lined up so I went over to inpect the spacers on them. Only two of the four had them, of the two, one was broken just like mine. What a joke.
that leaf and will definitely keep a close eye on that spacer now.
Thanks again for the kind words, have a great evening. |
My truck has a 6 inch rough country lift. The rear is about a 3 inch lift and 6 in the front. The rear sits about 1 inch lower in the rear. I do not have my factory block in there and that is the cause of that. I had the 35s on there with a leveling kit and it rubbed the springs. It drove me crazy. So I bought some 2 inch spacers put them on and then it rubbed the bumper and fender well. I then put on the 6 inch lift. I think it looks real good as it is. The only problem I have is when I'm towing it sags a good bit. You can see that if you look on my photobucket account. I am looking to take my lift off and put it back to stock so I can have a better advantage towing.
Thanks again for all the info. |
I have an overload spring. I like the way you did your help spring. I thought about getting airbags but Im just going to go back to stock and then if I need help there I can get airbags.
Thanks, I know you know alot about these trucks. Let me ask you this. My truck sits alot. Sometimes I go 3 weeks without starting it. I've heard it's bad for them, what do you think about that?
When it's sitting it should be A ok. Mine sits for weeks at a time as well |
