Track bar? - Ford Powerstroke Diesel Forum
Old 04-09-2010, 05:44 AM
Track bar?
Hey guys i just wanted to check where does the track bar mount on the driver side or the passenger side? Could you guys take a ppic of the location where i will be putting this bar?
I would greatly appreciate it thanks
shane
Old 04-10-2010, 07:05 AM
Can anyone help me it looks like a bastered to do because the oil pan is right there what do you guys do to make this work i am going to put the front end in tmro
Old 04-10-2010, 07:29 AM
the baconator
You're doing the D60 swap, right? did you get the OEM track bar and bracket? The track bar installs on the engine crossmember. But you need to remove the old brackets that hold the TTB, the track bar bracket reuses some of those holes. The drop portion of the bracket should be on the driver's side.
The bracket installs through the 3 holes here. With teh drop part on the driver's side (right side of photo)
Old 04-10-2010, 09:10 AM
Can you photobucket a arrow showing it to me I herd it was behind the oil pan
Old 04-10-2010, 09:12 AM
Yes I got the stock tracckbar and bracket
Old 04-10-2010, 11:48 AM
the baconator
The green is about where the bracket goes. The pink is where the three bolts go (be careful not to tighten them so much where they hit the oil pan). The yellow is the track bar
Old 04-12-2010, 01:40 PM
the baconator
hey man - did you get it all worked out?
