help, rear shock question?? - Ford Powerstroke Diesel Forum
Old 04-05-2010, 04:31 PM
so i went out to swap my 250blocks with f350 ones, and also i was gonna flip my blisten shock around so the boot was at the top? anyways the top bolt is a diff diameter than the bottom bolt, so i dunno how ppl are putting the boot upwards?
also i was hearing this loud knock when i went over bumps... its that bottom bolt to the rear shock.. its loose. the bolt isnt thick enough..
someone plz chime in as i want to get this done today because its going to rain for the next two weeks yay! BC!
Old 04-05-2010, 05:25 PM
bump
anyone had this issue with the lower bolt for the rear shocks being loose?
Old 04-05-2010, 05:31 PM
Originally Posted by INTERNATIONAL7.3 View Post
bump
Yes I know exactly what you are talking about. The bushings go bad, or swell due to weather. I had to take off all 4 of my shocks and replace the bushings make sure that you but that metal sleve in. If you dont it will wear at the bushing quicker and the knock will come back.
Old 04-05-2010, 05:48 PM
but its not so much the bushing thats bad... its more like the bolt that goes through the holes is not thick enough
ughh ill go snap a pic brb
Old 04-05-2010, 05:51 PM
Feedback Score: 5 reviews
Just curious...why do you want to flip the boot end to the top?
Old 04-05-2010, 05:55 PM
it doesnt fit
Old 04-05-2010, 06:05 PM
the top is nut and stud.. it only fits on THIS end of the shock. ( tried filpping it and there is no chance of it working.)
THIS is why i dont understand how some of you guys have the boot upwards? differant shock?
Old 04-05-2010, 06:09 PM
my OTHER issue is this bolt and nut
could i have grabed the wrong bolt? wtf i really cant see me doing that.
the diameter of this bolt is to skinny (hence why i was gettin that terrible knock)
SEE the air space
hope this helps
Old 04-05-2010, 06:10 PM
I'm still confused...why were you wanting to flip it in the first place?
Old 04-05-2010, 06:13 PM
because usually i see most trucks with boots up and i saw a thread a while ago saying yea it was pretty much preferance on which way you wanted it. up or down (it dont matter) is what i was reading.
