Steering feels loose - Ford Powerstroke Diesel Forum
Old 03-18-2010, 04:45 PM
Send a message via Yahoo to jwindbigler
I have had some problems with my steering feeling a little loose. I threw it up on my alignment race at school, and everything checked out. Caster, camber, toe, all good, but the steering feels loose.
A buddy of mine pointed out that I should have a steering dampner on the truck, and when I went to go and take a look at it, I saw brackets for one, but there was not one there.
My question is: Is there supposed to be a steering dampner on my truck, and if so, where can I pick one up besides the stealership?
2003 F250; 4-door; 6.0; 4x4
Old 03-18-2010, 10:08 PM
Steering damper yes, no? Maybe?
Old 03-19-2010, 05:14 AM
Steering stabilizers are not included on all trucks from the factory. It depends upon the options the truck was ordered with.
A steering stabilizer isn't intended to fix or mask sloppy steering. It's job it to moderate bump steer and other sudden inputs/impacts to the steering system which come from the road.
While your alignment may be within spec, I suspect you have some worn steering components. Could be the steering box, drag link ends, tie rod ends, or even ball joints. I would start at the steering box and work downward to the tire rod ends. Have someone move the steering wheel while you inspect the entire steering system for unwanted movement.
Old 03-19-2010, 09:31 AM
That is what I was thinking. I didnt want to get into the steering box if I could prevent it with the stabilizer. Dang, I really didnt want to have to tear into the thing, but oh well. I'll post pics when I do the job. Thanks again for your input.
Old 03-19-2010, 10:07 AM
if you throw a steerin stablizer on there it WILL help a lot.
Old 03-19-2010, 10:11 AM
My '03 had the brackets but also didnt have a stabilizer on it.
Old 03-19-2010, 12:33 PM
I just adjusted the box on mine. Mine was scarey loose, i almost wrecked a couple times from overcorrection. I made adjustments in very small increments to avoid binding in the box, but it has helped. I don't want to tighten it anymore, but it is still a little loose but not near as bad as it was. I'll be looking at drag link and tie rods next.
Old 03-19-2010, 12:37 PM
If the steering wheel is loose, like you turn the wheel but the tires don't move, a stabilizer won't help with that. I've seen some truck that could turn the sterring wheel at least 1/4 turn without getting a response, there was that much play in the wheel. The only way to fix this is to adjust/replace the steering box, and/or check steering component joints. Stabilizers are mainly for bump steer problem, especially when running larger-than-stock tires.
Old 03-19-2010, 07:01 PM
This is the issue that I have. Its not 1/4 turn, its more like 1/16, but I just dont like it. I find myself overcorrecting all the time. I am a new truck owner so the loose steering makes it difficult. So, I would like it to have more solid steering.
I'll probaby take it apart this weekend. Did you need any shims or anything, or is it just tightening a bolt to move the gear around?? I havent looked it up in my ford tech manual yet, so I was curious on real world what you needed to do.
Old 03-21-2010, 08:30 AM
adjust the steering box youll see a nut on the front of the steering box. loosen the nut while holding the bolt and allen wrench. turn the allen wrench 1 hole turn and tighten the nut back up. see if that helps. ive done this 3 times finally i just replaced the steering box last week and guess what steers like new! also just did all the tierod ends this weekend. i took it in for an alignment and the tech said 2 were bad. now its even better. who woulda thunk it..
