front leafs uneven
I have a 99 f-250 SD SC 4x4 built 2/99 with the 7.3.
the d-side has sagged an inch below the p-side. I want to get it leveled out side to side and at the same time level it front to rear. It now has the smaller f-250 blocks in the rear (came with the taller ones but I swapped them out). It still sits higher in the rear (p-side fenderwell is 2.5" lower in front than rear). now, since it is uneven, I know I have to replace the leafs. problem is, I have to be able to get this rig into my garage with a 7' door. it currently has 265's but it needs tires and I am going to go up to 305's or preferrably 315's. What makes this a problem is that most if not all 2.5" leveling front leaf packs say you have to have the f-350 block for it to be level. If I put it up that high, I am 99% sure it won't fit in the garage with 315's and 305's might be too tight. So, any ideas? I have thought that I could put stock replacements then add some shackles to get it a little higher than stock for an f-250, but I don't want to do that if there is a good set of leafs that will get me where I need to be. I also need shocks as these are the originals, so I was hoping to just get a leaf pack leveling kit-just afraid it will be too tall. If I wasn't limited by garages, then I would shoot for the sky, but I have to be realistic. and of course, price matters. I don't want to be putting a grand into getting it level any help is appreciated. thanks, Kyle |
no advice?
all I am after is a new set of front leaf packs that will sit me 1.5-2" over stock f-250 height. All the new packs I have seen for leveling have been to level an f-350 which I don't have. surely someone has advice? |
You could order the front springs from ford that they used on the snow plow equiped trucks. K code or something like that.
those were X code springs
I am afraid those are going to ride stiffer than what I have and I would like to improve the ride, not degrade it if possible. thanks for the response though My plan at this time is to purchase some of the 5 leaf diesel leveling springs offered by either Superlift, ProComp, Tuff Country, or Rough Country and install those and see how it sits. If it is too high, I will remove one of the leaves to make them 4 leaf packs (the gas engine leaf packs have only 4 leaves) and go from there Anyone have experience they would care to share with any of the above mentioned replacement leaf packs? |
Just be aware that the multi leafs that Super Lift uses are different then just adding a leave to gain height. Each leaf has a lower spring rate and when combined as they sell them gives the added height with out the harsh ride. I ran their 9" lift system back in 01. So removing a leaf might be ok, but more then that and I would be concerned about the over all spring load capacity. Aldo know that tires with a taller side wall will ride softer... so the taller tires you plan to run will give you some softness.
Why not just replace with stock springs, then add your tires, make sure you still fit in the garage then add a spring kit to the front to get your leveled stance? |
X codes will not give you a stiffer ride. I have em and if anything the ride is much better than it was with the Vcodes it came with. I vote X codes
