front sway bar making noise
i have an 03 250 cc already replaced front swaybar links once now there nocking on the floor board again is there any fix that i don`t know about?
did you replace the actual sway bar bushings aswell? mine were shot and it knocked right under the drivers side floor. just a thought
just like bigcow said, i had to replace the sway bar bushings and the end links just about a month ago. i could grab my sway bar with my hand and swing it back and forth with little effort...yikes! it sounded like hell hitting bumps
yeah mine was really loose, i picked up some moog bushings for mine from the irish mafia (oreillys) for 12 or 13 bucks i think
Is it the endlink itself that your having issues with?
I had the same noise, it turned out to be my sway bar bushings, the parts were $11.00, and he used Moog brand, said they were better, now my truck is finally quiet.
go with the poly ones from energy suspension. best money spent. i have had mine on there for awhile now and not a lick of problems or any hint of it going out again.
mine is still doing it after changing the bushings out for energy suspensin endlink kits and swaybay bushings. ive just lerned to live with it.
when i had my excursion, it did the same thing after changing the bushings. turned out to be the body mounts were loose and had to be torqued to hell before it would stop. excursions suffer from this all the time. maybe that is what you got there??
