Making a 4" into a 6" - Ford Powerstroke Diesel Forum
Old 03-14-2010, 12:57 PM
I've got a 4" pro comp lift and have been researching the pro comp 2" leveling kit. Pro Comp says you can run the kit on a 6" lift to make it an 8" but says nothing about if you can run the kit on a 4" lift to make it a 6". Just wondering if anybody knows of a reason why you couldn't use it for this reason. Thanks for the help guys
Old 03-14-2010, 01:32 PM
Its the same thing. You may would have to change out some of your steering components like pitman arm and stuff. It can be done though
Old 03-24-2010, 04:34 PM
I have the same setup you got (4" pro comp, leaf stack up front and blocks in the back). It had the lift in the truck when I bought it. After a few months I upgraded the pitman arm to the 4"-6" one, its helped A LOT, esp with the bump steer. I am looking at doing a 6" all spring lift now. From what I understand the 4" and 6" lifts use the same pitman arms, sway bar links and shocks. When you go to a 8-10 you need those changed, that is why I'm going to a 6"... $$
Old 03-25-2010, 06:08 AM
Does anybody have a 4" or 6" used lift for sale??
Old 03-27-2010, 04:45 AM
Send a message via AIM to WydOpen
I don't have a complete kit, but I have a pair of Fabtech 6" coils and rear blocks...no hardware. Look for my post in the classifieds section for more info. $150 plus shipping.
Old 03-27-2010, 06:44 AM
I'M not to familure with the lifts what else would
I need ?
Old 04-08-2010, 06:02 PM
I might have, i just got a truck and i am picking it up saturday. I think i want to run 20's on 35's with a leveling kit so the 6" with dual front shock kit will be for sale. Here is a link of the truck. its on page 6.
http://www.powerstroke.org/forum/tru...-lifted-6.html
