parts for leveling kit? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-12-2010, 05:39 PM Thread Starter
black974door's Avatar
i just bought a leveling kit from rough country. what all would i need to install them? they came with just the leaf springs pads, center bolts. im thinkin i will need u-bolts but what about shocks? the instructions didnt seem like i would need longer brake lines, am i right? oo i have a 97 f350 cc 4x4
black974door is offline
post #2 of 8 Old 03-14-2010, 07:54 AM
j440's Avatar
no you won't need longer brake lines. you can stretch your stockers up to about 6" (not much room to flex though)
Late 99 ECLB XLT 4x4 F250 STOLEN..now recovered
-DP tuner
-DIY intake
-08 Mirrors
-Gauges
-05 Grille
-Smoked cab lights
-35s w/ no lift
-4" straight pipe
1997 CCSB XLT 2wd F250
-STOCK!!!!!!!!!!
j440 is offline
post #3 of 8 Old 03-14-2010, 08:08 AM
szyd's Avatar
is it a add a leaf? or new leafs?. add a leafs just stack more leafs under factory leafs. the shock mounting points dont change. if it springs with more arch you will probably need new shocks. You will also have to lengthen the steering ling a bit to resenter youre steering wheel.
Dale
99.5 F 350 Totaled
2000 F350 Lariate
CC
SB
4x4
4" turbo back
cold air. Zoodad
Banks big head
Wicked wheel
4" BDS lift. With Bilstein's
all brought together by TW
szyd is offline
post #4 of 8 Old 03-14-2010, 03:51 PM Thread Starter
its just a single add-a-leaf. 1.5" nuthing big. made by rough country. thanks
post #5 of 8 Old 03-29-2010, 12:39 PM
Ray Bennett's Avatar
Im about to Put the same kit On my 02 250 hd PS , My mechanic friend told me all I have to do is adjust the steering, Rough country tells me I need to do nothing, I thought for sure I would have to get new camber and Caster Bushings Went to ask the ford parts guy and he freaked out on how bad it was for the truck? So I know this topic has been beat to death but what else in needed do to the 2inch leveling kit Proper for long team heavy duty farm use?
Ray Bennett is offline
post #6 of 8 Old 03-29-2010, 12:50 PM Thread Starter
lol im still not sure on whats needed. i havent done it yet. wainting for good weather and a friend to help. well a friend to do it cause i have a messed up shoulder and cant lift ****
post #7 of 8 Old 03-29-2010, 12:52 PM
szyd's Avatar
You will be fine. when it is all installed youre steering wheel will not be straight you just need to lengthen the steering link from the pitman arm to the grag link.
Dale
99.5 F 350 Totaled
2000 F350 Lariate
CC
SB
4x4
4" turbo back
cold air. Zoodad
Banks big head
Wicked wheel
szyd is offline
post #8 of 8 Old 03-29-2010, 01:01 PM
Thanks Much. And you are saying this will not change my camber?
