Grind sound when turning right? - Ford Powerstroke Diesel Forum
Old 03-08-2010, 10:20 PM
Help me troubleshoot this real quick, im making a 3000 miles drive this weekend.
Whenever i turn to the right, there is a grind sound. Its not constant. It only happens when the steering wheel is at a certain spot. It makes the grinding sound when i pass over that certain angle, and when i go over it again to straighten the wheel out.
If i hold the wheel in place where it makes the grinding sound, it doesnt continue to grind.
When it first started happening, it was just a little knick sound. Now when i do it, the grind is fairly noticeable, and i can feel it slightly in the steering wheel.
I just got all my ball joints replaced. Could a dry bearing be the culprit?
Old 03-09-2010, 01:45 PM
bumpity....
Old 03-09-2010, 02:54 PM
Try lubing the lower steering shaft where it goes threw the fire wall. There is a bearing there that gets dry and worn. You can feel the rubber boot with one hand and turn the steering wheel with the other to make sure that is it....
