6.0 steering problem - Ford Powerstroke Diesel Forum
Old 03-07-2010, 11:32 PM
I have a 2005 Excursion w/ a 6.0 PS. 6'' lift with 37s and now the power steering pretty is non existent at an idle. It is fine at anything above an idle, there is no leaks and no loss of fluid. the brakes are not effected either. I think it needs a new hydroboost pump, but wanna see if anyone can confirm or deny before spending the money.. please help with any info, it will be greatly appreciated...
Old 03-09-2010, 03:00 PM
Power steering pump the hydro boost only runs the brake system. Pump presure is week.
Old 03-09-2010, 03:06 PM
Chapter Director
i have the same problem and i have read that steering gear can be a cause of this to. said that it can have an internal leak causing low pressure. not sure how you prove it but it sounds possible
Old 03-12-2010, 01:49 PM
Put in a new hydroboost pump from ford, works great, any guy with simple hand tools can do it....so glad it was that easy of a fix///
Old 03-12-2010, 03:04 PM
Chapter Director
I have heard that ford has had like 5 revisions of the pump and that maybe they have higher pressure now
Old 03-13-2010, 05:58 AM
It was a hydroboost pump? Can you tell me what the difference is between a power steering pump and a hydroboost pump.
