Ball Joint Replacement 2001 F250 4 x 4 - Ford Powerstroke Diesel Forum
Old 03-02-2010, 10:33 AM
I had discovered that I need new ball joints for my 2001 F-250 SD 4x4
I was told that I cannot use a fork type seperator. Any suggestions on what type I need to finish the job.
Old 03-02-2010, 10:37 AM
Air hammer works to get the old one out, but you need a Ball-joint press to get the back in!
Old 03-02-2010, 10:39 AM
You can use a fork to remove the joints from the axle, from there you need a ball joint service tool. Harbor frieght has one. It works great! I am doing joints and bearings on my truck now. Not that bad of a job, just time consuming when stuff does not want to come apart........ that is when the Ac\Ox torch comes in
I have the $50 kit, and it works on my 4wd.... when installing the joints with that kit, do the bottom one first, then the top, that will save you a lot of cussing......
Old 03-02-2010, 10:45 AM
just did this on a buddiyies 2wd dually and we used a balljoint tool from its owner it was about a grand looks like a huge c clamp mated with a balancer puller have not seen the harbor frieght version. this came in a 2x2' box and a tone of high carbon rings to press in or out diff size joints
Old 03-02-2010, 10:52 AM
for got the link, sorry, little girl wanted lunch!!!!!!!!!!!!
Harbor Freight Tools
