flip track bar? - Ford Powerstroke Diesel Forum
Old 02-25-2010, 07:18 AM
flip track bar?
Can you flip the track bar from the bottom to the top on the axle side to give a better relationship between the two bars? i searched but couldn't find anything.
thanks guy
Old 02-25-2010, 08:22 AM
Yes you can.
Old 02-25-2010, 08:25 AM
is it simply unbolting it and flipping it or does it need to be reemed or anything?
Old 02-25-2010, 10:02 AM
It is a ball joint on the bottom end. Unbolt the nut and remove the trac bar, you might have to beat it down to get it off, I used a rubber mallet and it was pretty easy. The ball joint will need to be pressed out, you can rent a ball joint kit from the auto parts store for this for free. I had to cut an inch or so at the end of my lower trac-bar ball joint to get the ball joint tool to work. I didn't cut into the treads, just cut hexagonal section used for tightening. Depending on how many miles you have, it might be worth just replacing the lower ball joint anyways.
Old 02-28-2010, 03:17 PM
i just had a quick glance at mine & it looks like the track bar may interfere with the steering linkage if i move it but it would improve the relationship between the 2 bars.is that ever an issue? does anyone have a pic of that mod?
Old 02-28-2010, 04:51 PM
i didn't do mine this weekend or i would get pic up for you. It shouldn't interfer
Old 02-28-2010, 05:07 PM
No reason to do this unless you are at say 8"+ more like 10" lift...but this is indeed how the LARGE lifts run the track bar.
While your under there....measure the drag link, and have a solid one built up with heims on each end that you can adjust to center the wheel...take that 2 piece weak unit off there...you have just made major strength gains to your steering.
Old 02-28-2010, 06:59 PM
mine is just over 8" & looks like that would help. also i would like to go a little higher soon so i can go to a 40" tire.im on 37s now.does flipping the track bar shift the diff over at all ?
Old 03-01-2010, 04:31 AM
I would think it would shift the axle towards the passenger side by just a little bit.
Old 03-01-2010, 05:40 AM
You will want an adjustable trac-bar. I will get pic of mine up tonight when I get home.
