07 Lift on an 08? - Ford Powerstroke Diesel Forum
Old 02-24-2010, 03:52 PM
07 Lift on an 08?
Might be a dumb question, but why is it you cant use an 07 lift on new model SD's? The kits looks exactly the same.
Old 02-25-2010, 06:26 AM
the track bar drop bracket is a different shape where it tucks up against the frame,the sway bar drop is different front & rear. you can still make an 07 kit work but with no swaybars & a spacer needs to be fabricated for track bar drop.
Old 02-25-2010, 06:30 AM
and the steering stabilizer drop is different
Old 02-25-2010, 07:22 AM
i do believe the rear springs are different lengths as well by about 10 inches.
