small lift - Ford Powerstroke Diesel Forum
Old 02-24-2010, 08:16 AM
small lift
Hey guys i got a stock 1997 f250 powerstroke and was wondering what can i do to lift it small 2-3 inchs maybe.. do you make body lifts for the truck? and also would i be able to put a 3 inch block in the front and rear or just the rear?
Old 02-24-2010, 08:19 AM
You could do an add a leaf and get it up enough to make it sit level. You could easily tuck 33s with this option. Body lifts are a negative in my opinion. I don't like the way they look at all.
Old 02-24-2010, 11:11 AM
i have the same problem,
i have a 2000 f250 and i noticed that an exursion out at our lot has more leafs under the front end,
im on a tight budget but want to get a small lift in the front, could i just add a leaf or to and be fine ? and prob. but some small blocks in the rear ?
Old 02-24-2010, 11:13 AM
i got the same prob,
i have an 2000 f250,
i wnat about 2 inch up front
can i just throw a leaf or 2 in?
and a small block in the rear>?
i noticed that an exursion we have have more leafs in the front end?
Old 02-24-2010, 11:15 AM
Ford Lift Kits - 1997 Ford F250 4wd - 2.5" Suspension Lift Kit
This is what I have on mine. Put it on prolly 4 years ago...no problems, easy to put on.
Old 02-25-2010, 05:13 AM
Hey guys I was wondering if I would be able to put F350 front springs and rear springs in my 1997 f250?
Old 02-26-2010, 11:12 AM
i do as well?
Old 03-01-2010, 05:02 AM
will f350 springs fit?
Old 03-10-2010, 11:06 AM
anyonem help here?
