Ride rite airbags - Ford Powerstroke Diesel Forum
Old 02-23-2010, 06:18 PM
Ride rite airbags
I have ride rite air bags on my F250 and I put about 3000lb on truck plus tow a 7000lb trailer. tongue wieght is included in the 3000lb.
I have been told that the air bags should be removed and springs for an F350 installed as the air bags are for stability not load carrying,
Any insight would be appreciated.
Thanks
Mike
Old 02-23-2010, 06:20 PM
Feedback Score: 7 reviews
Send a message via AIM to dereku
I always thought airbags were for load carrying. I mean semi trucks use them instead of springs. just my thought. Anywho heres a bump
Old 02-23-2010, 06:44 PM
Super Duty 250 and 350 rear spring packs are the same. Some have overload springs depending upon the option packages selected.
I would keep the setup you have, as it's doing exactly what it's intended to.
Old 02-23-2010, 06:55 PM
Airbags are designed for load carrying....most guys install them for adjustability when carrying extra weight...dont change a thing.
Old 02-23-2010, 08:03 PM
I thought the 350 had a heavier spring pack which is why owners complain the ride is rougher.
I agree with the second part, your setup is fine.
Old 02-23-2010, 08:22 PM
Feedback Score: 5 reviews
they do, the 350 spring has more leafs the the 250 does, and the 350 has a thicker block.
Old 02-24-2010, 04:43 AM
hey All,
Thanks for the replies, I will save my money for something more important like an EGR delete.
Mike
Old 02-24-2010, 05:38 AM
I can tell you that my 2005 F350 leaf springs and my friends 2005 F250 leaf springs were exactly the same. Same number of leafs, part numbers etc. They both even had overload springs. The only difference was mine had a 4" (little under 4 actually) block and his had the 2" block.
