Where can I order these shocks? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-22-2010, 07:37 AM Thread Starter
BoDuke@ky's Avatar
Location: Northern Kentucky across the river from cincinnati
I got a 97 F250 7.3 with a solid axle conversion. it has a 4'' lift and I am in need of new shocks. I ran the Bilstein 5100s on my lifted 98 Tj, so I want to go with them. however on 4wheelparts.com, they are listed but does not specify the what size lift that they will fit. can anyone recommend a site to order from ?
BoDuke@ky is offline
post #2 of 5 Old 02-22-2010, 07:46 AM
dirtbily's Avatar
Send a message via Yahoo to dirtbily
What you need to do is remove one of the shocks and completely extend it. Then measure from end to end. Then completely collapse the shock and do the same measurement. Once you have this go to bilstein's site give them the specs on your truck (type and engine w/ type of lift) and they will get you new shocks hope this helps
02 7.3
zoodad, foil delete, 2x12s, 6" BW flares
6" black crome aussie stacks, 8" lift,
18" mazzi w/38"mtz, superchip,
smoked cab lights, driveway stainer mod
dirtbily is offline
post #3 of 5 Old 02-23-2010, 05:33 AM
Bilstein makes 5100s specifically designed for your truck with a 4" lift:
97 F250 4" lift front shocks
Required sleeve for front shocks
97 F250 4 - 6" lift rear shocks
shockguys is offline
post #4 of 5 Old 02-23-2010, 05:39 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 30 Post(s)
I"m thinking i need new shocks on the front of mine. I put a 2.5" leveling kit on 2 months ago and i had almost new shocks at the time and now both front shocks are bad. Will these Bilsteins work for that application?
Or maybe these for mine?
http://www.shockwarehouse.com/site/p...ount-BOOT-down)
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #5 of 5 Old 02-24-2010, 06:24 AM
Bilstein shocks and struts for cars and trucks - Shockwarehouse.com)
I would go with the F4-BE5-2818-HO that you posted.
Edit: Don't forget to use the discount code power5 for 5% off your order.
